Old 07-26-2014, 02:59 PM
yeeter yeeter is offline
Default 782 won't go
I have a 782 (new to me). When I push the hydro lever to forward .... nothing. Pull to reverse... nothing.
Another time I started it and pushed it all the way forward and it went (pretty fast, not slowest speed). Then another time I pushed all the way forward, it paused a few seconds, then made a screeching sound and took off.
Pulled the fender and the hydro linkage appears to be working as it should. The trunion is not worn at all (first one I have had that didn't have the trunion worn).
I took the tunnel cover off the the drive shaft is spinning.
While the fenders were off I pulled the top off the rear end and its plenty of hydro fluid (not horribly dirty).
Lift doesn't work either.
Could a filter clog and do this? (filter looks old).
I do have a spare hydro, but wasn't planning on using it for this one (just gave one away as well, dang, maybe should have kept it). A bad hydro seems to be a rare occurrence. Whats next to try?? (Filter I know but I don't have one, maybe time to go get some....)
But most likely the experts here will sort it out quickly.
Old 07-26-2014, 03:10 PM
Billy-O's Avatar
Billy-O Billy-O is offline
Me thinks your issue is an air leak draining hydro fluid out of the lines. Is why after some time your tractor shoots off after you engage the hydro.
Plow blade
#2 Cart
QA36 snowthower
Old 07-26-2014, 03:40 PM
Change the Hydro Fluid and Filter.
Old 07-26-2014, 04:00 PM
I knew this would be at least part of the recommendation - in the works. (do not pass go, do not collect $200 - at least not until fluid/filter change).
An air leak is a new one - an air leak where?
Old 07-26-2014, 04:14 PM
RChristensen RChristensen is offline
Inactive Member
Here is a long shot to check out but worth checking. Make sure the rear pin is good on the flex coupler to the hydro shaft. If a pin shears off the drive shaft will be turning but the hydro may not at times and may turn at times.
Old 07-26-2014, 04:16 PM
The pump will self prime.
While you have the rear end opened up, here is a real good opportunity to clean it up. Get a new cover gasket and then install you new Hydro Fluid and Hydro Filter.
Old 07-26-2014, 11:14 PM
SS5150's Avatar
SS5150 SS5150 is offline
I agree with the guy above-sounds like a driveshaft pin wore through or broke.
RUN IN THE RED
1872 project
Cub Cadet Pro Z 560 L
Old 07-26-2014, 11:24 PM
I say fluid and filter. If that doesn't fix it, come back.
Old 07-27-2014, 03:57 AM
cubby102's Avatar
cubby102 cubby102 is offline
Im guessing fluid and filter as well. Had a 129 that would do this as well as randomly stop moving and it had a clogged filter
Old 07-27-2014, 06:55 AM
So far in the pool we have:
Fluid/filter
Drive pin sheared
Other
Put your bets in, we will know which of these three a little later this morning... (oh, the suspense!!)
