When I got this 1200, there was nothing left on the brake pads. After some "oh crap" feelings, it was time to do something. I removed the remaining lining, which was extremely thin, cleaned up the metal, and epoxy'd some aluminum pads on the shoes. I used 1/8 thickness aluminum stock. After enough drying time, I installed the new pads. I had to back the adjustment quite a bit out so I could get the assembly together. By the looks of the adjustment, its back kinda close to where it started from the factory. Anyhow after about 2 hours of mowing, there have been no problems of the pads coming off or otherwise. The gulf coast around here is flat as a pancake, and I don't know if the aluminum will work in a hilly environment, but it seems to work ok here. Thanks, TB
brakes? man you take all the fun out of everything.
Old Racer saying " Brakes just slow you down"
![]() Seriously glad you got it fixed, let us know how the aluminum works out.
Using aluminum for brake pads is an interesting idea. I know Sam has used McMaster-Carr brake lining to reline brakes. Based on his postings, I purchased some material as well, but have not gotten around to using it. It is too thick as it comes and must be ground down prior to installation, so I haven't gone down that road yet. aluminum would be available in various thicknesses, so finding one that doesn't require grinding is possible. I like the idea, just not sure how long the aluminum will last. Would be very interested in updates on how they work.
It seems like AL would work wonderful if you know how to drive a hydro. I don't think I would want to treat them like "real" brakes, but you shouldn't need that very often anyhow.
I was working on tightening up my brakes and discovered that one of the discs is not true. How the heck does that happen?
fell off a jack when the wheel was off. seriously im not sure how it happens, ive had a few tractors with bent up disks.
The original butt in my 149 had bent discs. I have no idea how it happened either. They still worked ok.
