Old 06-08-2014, 10:49 AM
Default 72 steering wheel shaft
Hey guys,
I can't get the acorn nut back on the steering wheel shaft of my 72, threads are ok, but shaft looks slightly crooked, how can I straighten it out or can I maybe file the top to slightly taper it to get the nut started?
Old 06-08-2014, 11:04 AM
Try a different nut with the same thread see if it will go on, you may get lucky.
Up to 530 and counting...
Old 06-08-2014, 11:13 AM
Ok, thanks lew, if not, can I file the top of the shaft?
Old 06-08-2014, 11:39 AM
Wouldn't hurt to try.
Old 06-08-2014, 11:53 AM
I tried it and another nut, wouldn't go on, so I got a new nut to try.
Old 06-08-2014, 11:59 AM
You might need a die set Nikster. I can't verify but I think it's 1/2 x 20 maybe? And yes you can taper it but I would use the die if you can get one.
Old 06-08-2014, 12:25 PM
Thanks mike.
Old 06-09-2014, 12:36 AM
5/8" 18 tpi
Old 06-09-2014, 06:33 AM
Did you get it on Nick?
Old 07-02-2014, 08:45 AM
No I didn't, but I finally got the steering wheel off, so now can I buy just a new shaft, or get a whole new column? Or have mine repaired?
