Old 05-14-2014, 04:36 PM
kevin s sc kevin s sc is offline
Default New 104
I have this 104 and it has low or no compression. Mean while my 127 is in parts, many parts. The engine runs fine off the 127. Will the 12hp bolt right up? I have plenty of toys to cut grass with, just figure the cub is more indestructible for my teenage sun. I'll post more of the 127 later.
Old 05-14-2014, 09:56 PM
Berwil's Avatar
Berwil Berwil is offline
I'm going to say yes, yes it will. They're both narrow frames and both K series engines so have at it.
Bill
Old 05-15-2014, 06:11 AM
Bill
X2!
Old 05-15-2014, 08:08 AM
Hoadihcub
Guest
Posts: n/a
Had same problem with my. 105 had no compression, did a quick valve job cleaned all the carbon and it has tons of compression and runs great.
Old 05-15-2014, 11:36 AM
red56turbo's Avatar
Throw that 12 horse in there and don't look back. Should bolt right in. Good luck!
Josh
Diesel Cub Cadets...........
Old 05-15-2014, 05:24 PM
Thanks to all. I'll try to swap 'em out tomorrow. The PTO clutch probably needs a lot of a attention also and it has no fire. It will aid me in taking my time on the 127. I think it may be the valves I can feel air moving but not pushing and pulling, so something is happening in there.
Old 05-15-2014, 06:21 PM
Hoadihcub
Guest
Posts: n/a
That's exactly how my 105 sounded. Cleaned the carbon build up off the valves and runs great now.
Old 05-15-2014, 10:39 PM
EarlJ's Avatar
EarlJ EarlJ is offline
It will indeed fit.. by the by where in SC are you?
126 in surgery with weights, spring assist, 3 point and sleeve hitch
100 with woods finish mower and rear lift,
Nice 125 with super nice sweepster, 1782 Super Diesel,
1650,782D in surgery, 102 parts tractor..
3 Brinley plows, Brinley cultivators , rear scrape blade, front plows and custom built bedder attachment.
Old 05-16-2014, 07:58 PM
Just south of Charleston. I wish there more Cubs around here, I paid 200 for this one on Johns Island.
Old 05-16-2014, 11:45 PM
The 12hp is in. The PTO belt that came with it is too short. When the belt is installed I think it'll cut an acre. The deck number is 421 U 1113.
