Old 03-24-2015, 10:23 AM
Daniel1962's Avatar
Daniel1962 Daniel1962 is offline
Default Model 1200 aquisition
Good morning folks. I've got an opportunity to pick up a really
Nice 1200. Needs a little basic tlc. Just looking for general opinions & advice
The 100 gave me the Cub Cadet virus , now i need more!
Thanks
Dave
1976 Cub Cadet 1200 & 44A mower
1964 Cub Cadet 100,
No Attachments at this time, I do have a cart to pull stuff around.
Old 03-24-2015, 10:48 AM
Go for it! My 1200 is a reliable work horse and is my only WF gear drive. It is a lot of fun to control and handles well. If you only have a NF at this point, then you need to get a WF to add to your collection.
Old 03-24-2015, 11:24 AM
Be sure to check the engine mounting bolts and the iso mounts, also check the 3 pin driver for cracks.
Old 03-24-2015, 05:27 PM
sawdustdad's Avatar
WF gear drives are my favorites. Recently restored a 1000, It's a great tractor. Definitely check the iso mounts, and the three pin driver as already noted. Probably will need a driveshaft flex joint replacement, and maybe some clutch work.
Old 03-24-2015, 07:03 PM
bocephus1991's Avatar
Good cub! i have our old 1200 been in the family since 81! Overhauled last year repainted it a couple years ago!
Brian
Old 03-24-2015, 08:11 PM
Daniel1962's Avatar
Default Headlights?
Did these 1200's not have any front lights? I'd sure like to add them if possible
Dave
1964 Cub Cadet 100,
Old 03-24-2015, 09:19 PM
Dave
yes headlights were an option.
Old 03-25-2015, 02:03 AM
cubby102's Avatar
cubby102 cubby102 is offline
Headlights were a option. All that's needed is a fuse and holder put in the 2nd hole in the dash column and bolt the panel in
