Old 04-20-2014, 11:28 PM
EarlJ's Avatar
EarlJ EarlJ is offline
Default Upgraded spindles??
I finally have gotten back on the 126 project. During disassembly the left hand spindle broke. Since that happened I was thinking about upgrading both to 4 lug wheels with 1" spindles. I know that some of you have already done this, so could you guys tell me how? The best parts? Best place to find said parts? I'm dumping a ton of cash into this thing and could afford to save wherever I can. Any advice would be greatly appreciated.. Thanks
126 in surgery with weights, spring assist, 3 point and sleeve hitch
100 with woods finish mower and rear lift,
Nice 125 with super nice sweepster, 1782 Super Diesel,
1650,782D in surgery, 102 parts tractor..
3 Brinley plows, Brinley cultivators , rear scrape blade, front plows and custom built bedder attachment.
Old 04-21-2014, 12:27 AM
You can go to them, but I really don't think it's necessary. I've broke both the 3/4" and the 1" spindles. I don't think unless your going to be adding weight to the front (I.E. suitcase weights, loader) you need them.
That said, you can switch to the front axle off a WF. Or, make your own.... Or extrememotorworks.com sells them. If you buy the 1" spindles, you can use the hubs off a Lo-boy, they'll fit. But then your going to have a 5 bolt hub, with some silly looking big tires on it. Most of the guys that do this mod do it to a super. For the bigger machine, it makes sense. On a GT, I wouldn't waste the money for a hub style wheel, or the 1" spindles TBH. Just my
Old 04-21-2014, 08:50 AM
EarlJ's Avatar
The plan is to put a loader on it. Either buy or build one, most likely build simply because they are hard to find down here. Since I'm rebuilding now it only makes sense to to the upgrade now rather than later.
Old 04-21-2014, 10:07 AM
ccannon222 ccannon222 is offline
A front axle off of a 1535, or early 1541,1641, 1440 etc... will fit and have 1" spindles. Overall the axle will be an inch or two wider.
