I had the 106 out today, went thru the fuel system and got it running for the first time in a while and moving in the first time in a longer while. The creeper still works (yay!) and I fixed the clutch release mechanism which is the reason it was parked in the first place.
What I hadn't done in 2 years, was operate the PTO, which used to work fine. The belts and deck are free and turn easily, but when I engage the PTO...nada zip, zero. Are there some simple things to check to free up a PTO, or is it an R&R process? This tractor has been outside, but stored under cover, so it's not been rained on. Thanks ! John
61 and 63 Originals 123 (2) 782D 106, 147, 122 102 parts It's only original ONCE!
Did you leave the PTO disengaged while it was sitting? With the engine off, engage the PTO and lightly tap on the pulley with a hammer. It may pop free. Otherwise, tear it down.
It was indeed disengaged.......which appears to be the state it's stuck in.
Try hitting it up with PB blaster, then tap it with a hammer.
I had my 100 parked for several years with the clutch disengaged. The PTO triangular spring took a set and wouldn't work anymore. I replaced the spring, put it back together, and it worked fine. Now I always engage the PTO when I park the tractor, especially over winter.
John Proud Owner of a Model 100 and a Model 124. A homemade cart, 2 x 42" mower decks, a 38" deck, a 42" front NF blade, and a lawn sweeper! |
