Old 08-08-2013, 03:54 PM
greg9168 greg9168 is offline
Default Drive shaft in 1882 is not engaging motor
Hello,
Need a little help from the forum. I was mowing with my 1872 and out of the blue, it quit pulling and the hydraulics quit working. No leakage, so I thought to check the drive shaft going from the engine to the transaxle. Turns out it is not engaging the engine so of course its not turning the pump so I have no hydraulic pressure. I can push the drive shaft forward slightly toward the engine and it will engage. Has something failed in the coupling? There is no noticeable damage to where the drive shaft enters the rubber dust boot. Your help is much appreciated.
Thanks!
Old 08-08-2013, 04:11 PM
Can you post a pic of what you have for a drive shaft? Something sounds odd on this one. I'm thinking some one replaced the drive shaft at some point with a CV style from a later tractor and maybe put the wrong length shaft in it.
Old 08-08-2013, 04:31 PM
Darrell Darrell is offline
If everything is still original , sounds like it sheared a spiral pin .
Old 08-08-2013, 04:49 PM
Only drive shaft in a Cub that I know of that has a "Dust Boot" is the Cyclops style CV shaft.
Old 08-08-2013, 08:20 PM
V30crewcab V30crewcab is offline
his last few posts indicate an 1882, so maybe he just typed it wrong. or else this is a new machine.
1782, 1862, 1440(sold), 89 1050, 128, 70, some run some don't!
72 scout
IH 404 tractor
Old 08-08-2013, 09:43 PM
Check the rear for broken or missing bolts. It may have shifted back causing the shaft to come out.
Old 08-09-2013, 07:31 AM
Your right his other post's are about an 1882 so assuming that it is an 1882 and from what he is saying my guess is that the splines on the shaft are toast. Probably has never been greased and it's just worn out.
Old 08-12-2013, 08:58 AM
Default My bad, I did mean 1882 not 1782
Sorry guys for typing in the wrong model. I took the side cover off under the battery to access where the shaft is connected to the CV style connector. The connector is solidly mounted to the engine, but the shaft just turns in the joint. Does this mean the shaft has failed? IF so, where can I find one? Thanks so much for your help!
Old 08-12-2013, 09:19 AM
Time for a new shaft, this is from the Cub parts site.
Part number 759-3614P
KIT-DRIVE LINE 1882,2082
Price $364.12
You could also try the sponsors at the top of the page to see if they have a good used one.
