Old 07-26-2013, 08:46 PM
cub108 cub108 is offline
Default auto motive starter selenoid
i know i have asked this before but i never found out which one.
what automotive starter selenoid will work on my 109. i have a 88 ford selenoid that i know works. the tractor only has on little threaded stud. the auto one has two. (one that says "s" the other says "I") which one do i use.
last question. some automotive starter selenoids have diodes in them. does the cub cadet have a diode in the selenoid or no? if it does or does not can i use a selenoid that has a diode or not
thanks
mike
Old 07-26-2013, 08:53 PM
jimbob200521's Avatar
thanks
mike
I wish I could tell you which model and if it has a diode in it but I can't. What I can tell you is I on my 127 I got rid of yesterday, I did the same thing you have done. I bought a replacement solenoid from an older Ford from O'Rieleys for about $12.00 and it popped right in. It should have a little piece of paper in the box telling you which post to use in single post applications. Here's a pic of the old and the new Ford, I hope it somehow helps.
-Ryan
Old 07-26-2013, 08:57 PM
I checked to see if I still had the box and I do. I tracked down the part on O'Reilly's and here's the link. I lost the piece of paper telling you which post to use, but if you get this part, it'll tell you when you get it.
http://www.oreillyauto.com/site/c/de...1931&ppt=C0330
In the description is says:
"Brand Information
Contains spike suppressing diode on certain applications to extend ignition switch life and provide minimal interference with on board computers."
SOOO it looks like this one has a diode in it but it worked like a charm for me.
-Ryan
Old 07-26-2013, 09:06 PM
Merk Merk is offline
I used this one from Stens on a 126.
Starter Solenoid (Stens) part # 435-431 (used on a 71-1X2 thru 147)
Not sure if it will work on your 109.
Project Uncle Dick
Cub Cadet 70
Old 07-26-2013, 09:08 PM
thanks
on your new selenoid it should have an s or i. what did you connect your wires too and which one(s)
thanks
Old 07-26-2013, 09:14 PM
cubs-n-bxrs's Avatar
Wire in question should be connected to the s terminal.
Old 07-26-2013, 11:52 PM
i have this selenoid. it is out of an 88 thunderbird. do you think with it being a little fatter in size it will be ok?
really dumb question. how do i know what is the pos. side of the selenoid?
thanks again.
Old 07-26-2013, 11:53 PM
one on left is the 109. one on right is the thunderbird.
looking down is the pos. and neg the same thing for both.
Old 07-27-2013, 06:52 AM
Grampie Grampie is offline
Both large terminals are Positive! No Negative! And use S terminal for starting
Old 07-27-2013, 10:36 AM
thanks again.
The solenoids are the same. But why not go get a new one. That Ford solenoid is correct, and they are like $10-$15.... Just go get a new one. Oh, and Grampie is 100% correct!
