Old 07-23-2013, 02:45 PM
Default Hydro bolt, rear cover plate bolt sealers
Anybody want to recommend their favorite other than the specified CC stuff?
Old 07-24-2013, 11:41 AM
sawdustdad's Avatar
Bolt sealer? or gasket sealant? Not sure what you are asking about.
Old 07-24-2013, 09:24 PM
Either one. Looks like what CC used was something akin to plumbers putty in both applications..
Old 07-24-2013, 09:34 PM
My fav is this stuff used to use it when I rebuilt T-101A racing transmissions.
Hylosil
http://www.hylomar.com/index.php?opt...=65&Itemid=121
Most of the time I use Permatex Ultra Grey.
Old 07-25-2013, 12:05 AM
I may be missing something but I'm still not sure what we're talking about, I've never found sealer of any kind on a Cub Cadet... anything.
Old 07-25-2013, 07:36 AM
sawdustdad's Avatar
Neither have I. But, I've resorted to using a very thin coat of ultra black permatex on rearend and oil pan gaskets to ensure no leaks. This after several leaking rear ends despite careful installations.
Old 07-25-2013, 12:01 PM
The gray stuff squeezing out between the hydro/differential case. The last two I've had out had the same stuff there and on the bolts on the rear cover.
The bolts on both rear ends also had some type of black sealer on all bolts that held the axle housings to the differential case.
Seems like also, I've seen a CC part listing for bulk sealer to use on hydro differential.
Maybe not?
Old 07-25-2013, 12:14 PM
I think someone has had that apart before..... I've not seen that on one either.
Old 07-25-2013, 07:06 PM
Okay, I'll go back to sleep. Thanks.
