Old 07-02-2013, 08:28 PM
william1041200's Avatar
Default horsepower?????
my 12hp kohlers kick butt so why are there so many manufacturers running up to 27 hp kohlers?????? should I look to upgrade some? or is it a ' selling point'
104 to 127 conversion with dual 6x12s, hydraulics
snow/dirt plow
1200 Quietline 44" mower
QA-36 snow thrower
Old 07-02-2013, 08:37 PM
Your 12hp Kohler is almost a "square bore" motor, and has a very heavy flywheel. It makes as much or more torque than most engines with half again as much HP. Keep it!
Old 07-02-2013, 08:42 PM
Default gonna keep it trying to get ppl thinking ha ha
youre an awesome example of human thinking ! ! !
snow/dirt plow
QA-36 snow thrower
Old 07-02-2013, 08:53 PM
This is the info from the Cub site for the 1000 series
Series 1000
Lawn & Garden Tractors
•Mowing decks from 42 to 54-inches wide.
•Powerful engines, from 18 to 27 horsepower.
•Unsurpassed 3-year/120-hour and 5-year/500-hour limited warranty
MSRP Starting at $1,649.00
If the new "27HP" can only pull a 54" deck why could the old "17HP KT17" pull a 60" deck in a Super that weighed more? It's all marketing BS.
Old 07-02-2013, 08:57 PM
amazing how marketing outsells the epa fines
snow/dirt plow
QA-36 snow thrower
Old 07-02-2013, 09:12 PM
If you want to take it even further the O came with 7HP and a 36" deck so 14HP for a 72" deck? Why do we now need 27+HP OH yeah HP sells and the bigger the HP number the more we can charge. I could go on but I would be banned for life LMAO
Old 07-02-2013, 09:24 PM
LOL.....I run a 50" deck on my 14HP, 1450 every week.....Imagine that.
Old 07-02-2013, 09:57 PM
machinehead323 machinehead323 is offline
i was wondeing this too. my push mower has a 6.75 HP engine and my original has a 7. amazing what some torque and gearing can do. i went to the kohler site and the 27 hp command pro, heres the specs
Model Command PRO CH740
Max Power @3600 RPM hp (kW) 1 27 (20.1)
Displacement cu in (cc) 44.0 (725)
Bore in (mm) 3.3 (83)
Stroke in (mm) 2.6 (67)
Max Torque lbs. ft (Nm)1 42.3 (57.3)
Compression Ratio 9.0:1
Dry Weight lbs (kg) 94 (43)
Oil Capacity U.S. quarts (L) 2 (1.9)
Lubrication Full pressure w/full-flow filter
Dimensions L x W x H in 14 x 17.7 x 26.5
Backpressure Limit 2 50
J1995 Power hp (kW) 3 24.4 (18.2)
J1995 Torque lbs ft (Nm) 3 37 (50.1)
just from my thinking i always want more power. when looking for a cub i wanted the biggest i could find so i got a 1650. ive always wondered if i got a different model would i be satisfied with a smaller engine. my O does not run yet so i have no comparison. when the people in the neighborhood ask what size engine is in my cub they seem astonished it only has 16 hp.
1979 1650, #1 tiller with one extension, 90 degree box mounted, 3 point. 1961 4 digit bringing back to life. I have the mower and 3 pint for it. The 1650 is the fastest mower in the neighborhood.
Old 07-02-2013, 10:37 PM
Wanna see some of what a 1450 can do?
Check out this thread
http://www.ihcubcadet.com/forum/mess...tml?1372815001
Heck, my 1000 can do almost as good under these conditions albeit at a little slower pace. These 50" ddecks give a better cut than my son's Cub 48" zero turn.
Dave S
Old 07-02-2013, 10:49 PM
That is an exaggeration Sam, I gotta call you on it. The 7HP would only pull the deck in low gear if any reasonable amount of grass is present to cut.
If you are mowing in 2nd, you ain't pullin' this grade, or cuttin' this thick of grass;
14HP of ANY bore/stroke and flywheel ain't gonna pull this 72" deck. even in first gear.
Onan is known as a high torque engine, and 24HP is barely enough at the speed I cut at.
The high HP machines will allow much faster ground speeds. I do not think it is all marketing hype.
Some, yes, but, not all!
JMHO
