I am rebuilding the mower deck on my 1864.
I have replaced all the bearings and seals in each of the 3 spindles. Timken Set2 bearings (11910/11949) Timken 471737 seals All three are back together now, but 2 of them are very tight - hard to turn by hand. I did install the center spacer between the bearing cones. All the races are seated fully in their bores. Is this normal, and will they loosen up after they run a bit? Or should I disassemble and shim the bearings out a bit so they turn free? |
Well, I can't feel them from here... LOL. But I would say shim them up. They should be snug, but not tight.
![]() Quote:
As a youth, I saw MANY bearing failures on shade tree mechanics cars where they "snugged" the front wheel bearing. (They were always taking the bearing apart to replace the drum brake shoes, ![]() Car bearings run "somewhat" slower than spindles. ![]() I think you also need some "slop" for thermal expansion!! ![]() |
![]() Quote:
![]() Quote:
THEN, you backed it off, IIRC, it was one flat of the castle nut. ![]() With about 20 threads per inch (?) that would equate to 0.008". Maybe too much for a spindle, ![]() If it is too tight, the bearing will be happy to spall. ![]() http://en.wikipedia.org/wiki/Spall |
![]() Quote:
So, if I was to start over, I would say... Put the new bearings in, and without a spacer tighten them down until you feel them drag. This will "seat" the bearings. Back the nut back off. Install the spacer and guess on the amount of shimms. Then tighten the nut up against the bushing and added shims, then put an inch pound torque wrench on the nut with it set to about 10 In Lbs. (That would be the middle point on the specification of 5-15 InLbs. If you don't have an inch pound torque wrench, you can rent one from an auto parts store.) If it's too tight, add shims. If it's too loose, remove them. Do this until the torque it takes to turn the shaft gets within the spec. Every time you add or delete shims, roll the shaft several times before you take a reading. Also, put oil on the bearings. DO NOT do this dry, it will throw off the measurement. This method should get you really close to original. Is that a better way to explain how to set them properly? I guess I wasn't really very detailed or in depth the first time. And by feel really wasn't an answer was it ![]() Good Luck!! ![]() |
When I worked at GE, we found the typical male worker could turn a nut-driver to very close to 10 in-lbs, almost EVERY time.
So, if you have no torque wrench, maybe a nut driver and a BUNCH of adapters to get 1/4" drive up to the socket size would be closer than nothing!! ![]() |
Decades of messing with cars leaves me with a pretty good feel for how tight a bearing should be. Of course there is no castle nut or other provision for backing off, though I have considered red loctite. Safety wire is also something I considered.
Good to know there is a spec, thanks for that. I think I am going to find some .75 ID shims and get this right. I think as long as it's down I'll get some 1.25" stock and make up some new seal bushings. Mine were too rough for me taste. Am I the first one to run into this? Thanks for the input. |
