Old 03-21-2013, 05:58 PM
Donovan M.'s Avatar
Default Sea Foam
Have anyone ever used sea foam before. I have and that was with the 100 before the red and white. Or when it was original. The old ten horse seemed to gain more power again after i put some in it.
Donovan:
62' Original-fenders
Old 03-21-2013, 06:25 PM
I use it in all my small engines even my Harleys. No idea what they make it with but it works. Great stuff if you have a carb that is crappy.
Old 03-21-2013, 06:49 PM
mrmiller mrmiller is offline
I use Sea Foam in all my small engines also. It is just a good all around engine treatment and stabilizer.
Old 03-21-2013, 07:08 PM
MrGitrdone41's Avatar
I use the stuff all the time at work on lawnmowers and Garden tractors. It works great for the fuel system.
1988 1812,dual ports
1973 108
1968 125
Old 03-21-2013, 07:11 PM
Donovan M.'s Avatar
I just wish it wasn't nine bucks a can.
Donovan:
Old 03-21-2013, 07:36 PM
I have a question. I use MMO and Startron. Can you put too much extra stuff in todays fuel?
Old 03-21-2013, 07:42 PM
Grampie Grampie is offline
Oak, Why would you put anymore in than the directions call for?
Old 03-21-2013, 09:38 PM
Merk Merk is offline
At a plow day I tried sea crap and my 100 would die and 149 was way down on power. I drained the gas out of both and replace gas that didn't have sea crap in it. Both ran like they should.
I known a few that swore by sea foam. The stuff does break loose carbon build up. Two Kohlers start using oil after the sea foam treatment.
I wouldn't use snake oil products like sea foam. There is no quick fix in a can out on the market.
Project Uncle Dick
Cub Cadet 70
Old 03-21-2013, 09:52 PM
Donovan M.'s Avatar
I have never have had a problem with any fuel treatments or additives.
Donovan:
Old 03-22-2013, 08:18 AM
cubs-n-bxrs's Avatar
I've tried Seafoam and have never noticed any difference in performance or operation. I will just stick with treating my fuel with Startron. Every air cooled engine I own runs better with Startron treated fuel. Cold starts in the winter is where it is reall noticed.
Gee Dale lets not pull any punches Sea Crap LOL
