Guys,
one of the tabs that is used to hold the grill screen onto the cast iron grill is broken off of my tractor. My first thought was to weld a tab on since its weight bearing capacity wont matter its just gotta hold a 1/2 lb grill. Any other ideas?
Cub 104 Refurbed Sprinig of 2013 Aftermarket headlights, 3 point, Brinly Adapter, Spring Assist, 42" IH Blade, 42" Mower Deck, 42" Craftsman Grader Blade, 10" Brinly Plow, 6-12 ags and 22x9.50 turfs |
Weld! Weld!!
You make NO mention of the Model of tractor you are working on.
sorry 104, i put it in my sig but i guess some of you guys have a 100 of these things.
How about some JB weld?
jb weld would probably work. I have a welder though so I figure that would work as good if not better than jb weld and I don't need to buy anything. I know welding cast iron usually doesnt work but thats more for weight bearing stuff. for just the grill screen a little wire from the mig should hold it.
![]() Quote:
Cast Iron can be brazed or stick welded with nickel rod or a cast iron rod that contains nickel.
a normal wire welder using regular wire will not stick sufficiently. |
