I have a 127 with a k301as. Just got done tearing down the engine and found that the oil pan has a crack where a rock must have hit the deep sump portion near the drain plug. I've been looking at deep sump pans for the k301 on epay and each has subtle differences. Will any of these deep sump pans fit the k301 block?
Also, I noticed that the bottom of the tappets appear scored/pitted. Is this a problem and, if so, where do I find replacements? |
The k 301 321 and 341pans are the same.You want a cast iron one, the aluminium ones tend to get cracks/stripped out mounting holes.
You can put and ad for your needs in the wanted section.
replace the tappets while you are in there. check out the sponsors on this website. they should have what you are looking for.
CC 123 402c Sickle Bar, 48" Mower Deck QA42A Snow Thrower, 42'' Push Blade IH Back Blade and Rake Brinly Seeder/Aerator Brinly Lawn Rake Brinly 10" Moldboard,Brinly Cultivator, Brinly Disc |
