I parked my 782 back in July-August and finally got it started today, but when I did, there was no reverse whatsoever! I filled the transmission with fresh Hy-Tran and it has always had a really strong reverse before I parked it. Everything runs excellent on it, except no reverse. Could that be my hydro filter being clogged? Help-I've never experienced this kind of a setback before!!
Thanks in advance for your advice and interest in my thread, Cub Cadet 123
Still don't know what I'm doing in OHIO?.....If you find me, then please point me back toward INDIANA. ![]() |
Sounds to me like one of your hydraulic dump valves is stuck.
149,682,1641,1711 with a 12hp in it 1 8" brinly plow 1 10" brinly plow 451 snow blower,H-48 International snow thrower 42" york rake with fold down grader blade. |
Wow, thanks for the fast response Cubs-n-Bxrs! Ok, they are automatic dump valves, so how do I remedy that if it is the case?
To be sure that is the problem you can swap them and if after you swap them you don't have forward then it's time for new a new valve.
![]() ![]() Take both of the valves out ant tap them on a hard surface on the nut end. Reinstall them and try your hydro. It should work just fine. I had one stick on one of my 782s and it has not done it since. Good luck. Brian |
![]() Quote:
![]() Quote:
Glad u got it figured out wouldn't have thought they would fly apart! Wow
1782 smoker!!, 169 and parts 128 And a bunch of stuff that fits on the back of them LOL |
A new one, or one that had been properly repaired would not have come apart. Several years ago I came up with a way to take them apart, replace the bad o ring, and properly weld them back together.
I was worried about sharing that information in fear that some one would not weld them correctly so I made sure to explain that if they came apart the parts could go into the hydro and cause major damage. I see a lot of people repairing them and advertising them for sale. I just hope they are doing the repair correctly. |
Maybe you don't know your own strength! Just tapped them too hard!
Anyway, if the PO had taken care of this tractor, you wouldn't have it now!
John Proud Owner of a Model 100 and a Model 124. A homemade cart, 2 x 42" mower decks, a 38" deck, a 42" front NF blade, and a lawn sweeper! |
