Old 04-02-2013, 06:12 PM
vartz04 vartz04 is offline
Default implement lift handle issues
I'm trying to reinstall mine and I'm clearly missing something. It won't move once I tighten down the screws for the ratchet part that locks it in at different heights. Any tips?
Cub 104 Refurbed Sprinig of 2013
Aftermarket headlights, 3 point, Brinly Adapter, Spring Assist, 42" IH Blade, 42" Mower Deck, 42" Craftsman Grader Blade, 10" Brinly Plow, 6-12 ags and 22x9.50 turfs
Old 04-02-2013, 06:16 PM
are you missing the spacer that goes between the frame and part that locks the handle in at different heights, possibly.
Old 04-02-2013, 06:18 PM
Bingo. Not sure where that would of went but I currently don't have a spacer on there. Had to be there before since it worked fine before I tore it apart.
Old 04-02-2013, 06:20 PM
ok yea you need it, the bolts run through the part that locks the lift handle in and through the spacer and through the frame where you install nuts and washers ,hope i helped
Old 04-02-2013, 06:32 PM
Yep you did. Found it in the pile of primered parts. Thanks.
