Old 10-11-2016, 02:41 PM
mrjeep81's Avatar
mrjeep81 mrjeep81 is offline
Default No name yet
Here's a few shots of things I've been working on for my next tractor. And before this goes somewhere I don't want it to, I am not doing this because it "needs" to be done. I'm not even doing it because someone else "needs" it done. I'm just doing it because I can, and, I want to.
1450SGT
1641
528 SWE Snowblower,
Old 10-11-2016, 05:08 PM
52'F-3 52'F-3 is offline
I like it so far.....
also did you change the offset of the rear wheels?
Old 10-11-2016, 05:27 PM
DoubleO7's Avatar
DoubleO7 DoubleO7 is offline
AMEN
pretty sad day when a pre-emptive statement has to be included in your posts.
anywho, are those golf cart hubs?
Old 10-11-2016, 06:27 PM
twoton twoton is offline
Looks cool, eager to see more!
Old 10-11-2016, 07:54 PM
DieselDoctor's Avatar
Interesting! Keep us posted!
Old 10-11-2016, 09:54 PM
mrjeep81's Avatar
Originally Posted by DoubleO7 View Post
AMEN
Trailer hubs, golf cart tires and wheels I created the axle"extensions" by centering 1" bolts and then machined them off for the correct squeeze on the taper bearings in the hubs, removed the factory stop for the sealed bearings and machined the bearing stop/seal surface then welded them on. Yes, I drilled the spot welds and moved the centers back to mimic "super" rear wheels. This is going to be a Quiet Line SGT.
1450SGT
1641
528 SWE Snowblower,
Old 10-11-2016, 09:55 PM
john hall's Avatar
OK, let me get this straight, you're building a custom front axle/steering and are then going to build a Cadet around it? Well that's a different approach! What about the tires, you staying with that tread pattern or switching to something more like a lawn mower, or something resembling tractor style tread patterns? What you have done thus far looks pretty good.
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
Old 10-12-2016, 11:15 AM
mrjeep81's Avatar
Kind of. The axle and wheels were accessible, and I could fiddle with them when ever time allowed. The front tires will be fine as this is intended to be a BIG mower with power steering. My wife and I are deep in the throws of the "mid-life downsizing thing" and our new home is nearing completion, so "free" time has been and will continue to be elusive. I have 2 quiet line frames as well as a nicely scored 2072 stripped chassis that still had the power steering column and valve/cylinder in tact as well as the dual brake pedals. But planning for the up coming move, my welders are disconnected and the new garage may not be "set up" till late winter. (we're hoping for a good snowmobile season this year).
1450SGT
1641
528 SWE Snowblower,
Old 10-12-2016, 01:15 PM
Looks like the outer bearing is supported on the extension that you machined and that is only supported by a 1/2" bolt. Let me know how that works.
Old 10-12-2016, 01:24 PM
If it was me I would use a spindle like this. Ultra-Tow Axle Spindle — 1 1/2in. Square, 8in. Long
http://www.northerntool.com/shop/too...2387_200442387
