Old 07-10-2012, 01:01 PM
jcsmith jcsmith is offline
Default another 104 question
Front wheel bearings. I have 1 cub front wheel with bearings marked Luico Worcester, Mass. USA. Are these factory? The other 1 has Heim bearings,RF12-22-14APJ . Anyone have opinions as to which are better? Both are open back for repacking w/ grease. Anyone ever put a zerk in hub rather than disassembly for repacking? Thanks, Chris
1968 104 , service replacement '96 K301, 42" deck
1997 Scotts 42502X8 , repowered with '96 B&S 18hp TwinII , 42" deck
2007 LA130,21hp Intek v-twin, 48" deck
As you slide down the banister of Life, may the splinters point in the right direction .
Old 07-10-2012, 04:11 PM
ljones's Avatar
ljones ljones is offline
Yes people have put zerks in the hubs, some cubs came with them.
Old 07-10-2012, 05:00 PM
If you decide to put a grease fitting in the wheel, also put some sort of spacer between the two bearings to take up as much of the empty space between the bore of the wheel and the spindle as possible so you don't have to put half a tube of grease in there the first time (or make a gigantic mess when you need to remove the bearings for some reason).
Old 07-10-2012, 09:28 PM
ljones and Matt G ; thanks for the response
