Old 06-08-2012, 09:56 PM
Cadet Yellow's Avatar
Cadet Yellow Cadet Yellow is offline
Default Problem with Oregon 83-300 hydro filter
Stopped at the local CC shop today and they sold me an Oregon hydro filter. It is stamped that it is a replacment for the CC #723-3014, JD #AM39653 and MTD #727-0162.
I took off a Fram PH16 from the Cub Cadet Model 129 built in 1973. The Oregon filter will not screw onto the threaded hydro post. I checked the take off Fram filter and the Oregon filter center hole diameters and they seem to be the same. I wonder if they cut it with the wrong thread size ??
Anyone know what the issue may be? Is there a different hydro filter size for the earlier models?
I looked on the Oregon website to get the specifications for hole size and thread with no luck.
Thanks for any info,
Kurt
Cub Cadet 1450 with model 2 Tiller and 44" mower
Cub Cadet 129 with 44" mower - needs a lot of work
hand turned custom game calls
http://www.densmorecustomcalls.com/index.html
Old 06-09-2012, 06:29 AM
Did you check here.......??.... Hydro Filters
BTW....The Fram is a big No No....It is NOT a hydro filter.
Old 06-09-2012, 07:44 AM
Thanks Roland,
Yes, I have the chart.
I recently acquired the 129 and the PH16 was on it.
The Fram website cross references the PH2844 as a recommended alternative to the IH 723-3014. The main difference between the PH16 and the PH2844 is that the PH16 has an anti drain valve. Not sure what the ramifications are for having an anti drain valve on a hydro filter.
Kurt
Old 06-09-2012, 08:13 AM
The anti-drainback valve filters (NAPA part #1084) can be used on the Sunstrand pumps but if you have the Cyclops and up go with the NAPA 1410 or Wix 51410. The 1410 & 51410 can be used on either type of pump. If you have an older machine with the Sunstrand pump the 1084 filter will not let the oil drain out of it when not running.
Old 06-10-2012, 12:15 AM
Figured it out.
The size and thread of the center hole is correct but the threads were not cut very clean. Ran a tap through the hole and it still wouldn't go on. The beginning of the thread was double cut and I just couldn't get it started on the shaft.
Bought the NAPA 1410 and it worked fine.
Yep, weird.
Kurt
Old 06-10-2012, 04:25 AM
Originally Posted by Cadet Yellow View Post
Figured it out.
Yep, weird.
Kurt
ISO 9000 says 1 failure in 6,000,000 items (or something like that)
You are 1 in 6,000,000, you must be very special!!
Old 06-10-2012, 07:49 AM
Figured it out.
Yep, weird.
Kurt
I'm hoping you took it back/exchanged it for a properly made filter.
Old 06-11-2012, 09:10 AM
Wow......I don't feel special......just frustrated.
