Old 05-28-2012, 10:58 PM
silverthornethan silverthornethan is offline
Default Electric lift help
Does anyone know of a switch that will work for an electric lift on a 122. I restored mine and the switch was bad and I don't want to give 50 for an Ih switch. All help appreciated
Old 05-29-2012, 06:48 AM
One would need a DPDT - Center Off, like this.............
Old 05-29-2012, 11:24 AM
Why not post in our forum in the wanted section....many times a fellow member will offer help with parts that you need at reasonable prices!
Old 05-29-2012, 04:06 PM
TheSaturnV's Avatar
Be aware that if it is the original switch (shown below), they are somewhat repairable. You can pry up the tabs on each end and pull it apart. Inside are simple rockers and springs. On the end of each rocker it a contact point, which can simply be filed clean. I repaired mine this way and it works fine now.
HTH
