Old 12-08-2011, 05:54 PM
krhoover krhoover is offline
Default Wheel bolt patterns
Are the wheel bolt patterns the same on most of the models. I was reading on the thread about "hydro or 3 speed for plowing" and about the different tire sizes. I was wondering if I could swap wheels from my 122, 126 to my 1450? Also, while we're talking about wheels, I see that IH wheel weights weigh, I think about 40 lbs each? Is that enough to make that much difference when you compare it to the weight of the person on the tractor. I don't know what you guys weigh, but I easily add 240 lbs to the tractor, which would be right over the wheels. 80 more lbs added just seems like it's not enough to make that much more difference.
Old 12-08-2011, 06:04 PM
All the wheels are the same in terms of bolt pattern.
The IH wheel weights come in at about 27lbs/ea. The weight directly on the wheel adds more force than you think. Yes they help a lot, but liquid filled tires can be almost 3 times that weight each and costs about half or less then the IH weights.
Old 12-09-2011, 04:36 PM
ok, thanks once agian.
