Old 11-09-2011, 02:20 AM
CCSuperMan's Avatar
Question 1250 deck pulley question ...........????
Quick question on the pulleys . Neighbors' deck squeals like a Deliverance pig when engaging . I brought one into work and disassembled it . The large length bearing was good , but Im wondering just what supports the other end ??? Im on partstree looking at the diagram and the only thing Im not holding is the spindle housing cap . What Im wondering is , perhaps the PO installed the spindles without the top cap and this is why the deck doesn't work .
(he has never been able to get it to work)
Old 11-09-2011, 02:51 AM
CCSuperMan's Avatar
Uh huh . After further inspection .............2 bearings pressed into a hub that I can match up . Sealed bearings ?? No retaining rings ?? Do these cap plates locate and pinch the hub ?
Old 11-09-2011, 05:52 AM
I see you make NO mention of the size or model number of the deck you are working on. This information would be most helpful for an accurate response.
Old 11-09-2011, 12:43 PM
CCSuperMan's Avatar
Roland , this is it . Thanks ! Looks like the end caps capitivate the bearing housing and that is the only support .
http://www.partstree.com/parts/?lc=c...&dn=0074200002
Old 11-09-2011, 01:14 PM
CC1650Dave's Avatar
Your deck has the sealed, non-serviceable bearings pictured here (the posts preceding that one in my thread have more stuff I learned on the spindles and bearings.)
If it's squealing, it's likely the unit will need to be replaced. The replacement that CC sells is for a whole spindle (you can't buy just the sealed bearing new anymore) and I believe the replacement unit does have user-serviceable bearings. It's not cheap...seems like it was around $125.
You may be able to pick up a used spindle bearing from one of the sponsors if you want to go that route.
Old 11-09-2011, 04:18 PM
CCSuperMan's Avatar
I just saw the provided link . Guess I WON'T be pressing the bearings out after all !!! Nice pics and info
