Do blown out tail lights cause the headlights not to work??? I got 2 tractors that are stumping me on head lights. As far as I know everything plugged in on the switch, connectors are plugged in, bulbs are good, fuse is good. So that got me thinking that maybe since the taillights are busted out, that, might like short out the headlights? I don't know what else do I got to look for.
Nick. ![]() Cub cadets 100, 125, 86, 108, 109, 128, 129, 129, 149, 149, 169, 1450, 1650 and a handfull of parts tractors. #40 box blade, ih back blade, rear ih rock rake, #2 cart, windbreaker soft cabs, windbreaker hard cab, cozy cab, kwikway loader , wards corn planter, brinly plows, culitvator, rear blade, disc and the usual decks, snowblowers and 2 tillers |
No they don't, my 149 before starting on the rebuild had one working head lamp, and one working tail lamp!
Have checked your light switch, it's only 2 wires, a hot in and the lamp side, are both hot when the switch is on?
Jeff Brookfield, MO ________________ IH Red 782 with weights and sleeve hitch! IH snow blade, Brinly plow, Brinly disk, Brinly harrow, Johnson rear blade, and a #2 IH Cart |
Man that is a lot of Cubs you own . maybe the most in this group?
start checking with a test light / multimeter -is my suggestion - overcharging? & blowing bulbs-- bad ground ? 128 |
Check to see if your headlight wire is not worn through where the hood hinge is.Then check your switch with a meter....
