Old 08-29-2011, 12:12 AM
Default Advice needed
My 128 lift lever button rod is froze - any recommendations on how best to free it . -here is what I have done I have sprayed and sprayed with rust penetrant at the button with it draining down - drilled a 1/16 hole just above the casting to spray there and sprayed the bottom . I knocked out a roll pin trying to separate the lever but the lever is really seized in the casting It doesn't look like the whole casting would come off with the stepplate /fenders on tryed a mallet on the button and a muffler gun on the base I imagine it seizes at the casting I have a oxy/act torch and have heated the bottom there is a small side button on the lever it moves ok
Labor day I was able to beat down the button and move the lever will keep spraying & working it Thanks all !
128
Old 08-29-2011, 01:03 AM
cub1450's Avatar
cub1450 cub1450 is offline
Is it froze in the up or down position?
Jed
1975 1650SGT Work In Progress
1974 108 (Mint) #510358
Old 08-29-2011, 09:46 AM
Froze in the locked position is the small button( on the frt of lever) a lock for the other button? I'm going to try torching it more at the casting ,after it soaks again thanks
Old 08-29-2011, 09:58 AM
Have you tried soaking the mechanism with....??
Old 08-29-2011, 02:19 PM
Yes it's soaking with blaster now and have tried 3-4 different penetrants - the only bushing area is at the pivot casting right? the lever itself is free. the lower pawl pin position tells me it is 1/2 down I drilled a 1/8 hole in the lever side above the casting and fill it with blaster I'll keep doing that for 3-4 days to see what happends
Old 08-29-2011, 05:13 PM
cub1450's Avatar
You could unscrew the button with a pair of vice grips and spray straight down in there.
Jed
Old 08-29-2011, 09:33 PM
There should be a hook on the bottom that adjust into the saw-tooth bracket down inside the frame that allows for ht. adjustment. Get a pair of vice grips on that, make sure it is down so it doesn't lock into position on the saw-tooth bracket and try to twist it to the front of the tractor and to the back of the tractor. This forward and backward rotation has helped me free up some of mine when they were locked.
