Old 07-15-2011, 08:48 PM
samspops samspops is offline
Question Kohler voltage regulator location?
Hello all, i have a Kohler command 20 hp engine and am trying to locate the voltage regulator. the application i have is too difficult to take off the front shrowd(where i think it is) is there any other way to get at it?
Original Cub Cadet/creeper/fluid filled ags/3 rib fronts(Third one I've owned)
Ih rear blade and rake
MF 10/3pt/all the toys(sorry but i like it)
MF 12 under construction(sorry but i like it)
IH 560 tractor
'47 Ford 8N Tractor
'85 Ford F 250 7.3 IH idi diesel
'99 Chetech Pug 4X4
Jari Monarch sickle mower
Old 07-15-2011, 08:51 PM
The rectifier should be bolted to the outside of the flywheel shroud...I can't remember which side. At any rate, it's pretty much out in the open and easy to get at.
Old 07-15-2011, 09:00 PM
Talking
Thanks for the snap reply Matt. the application isn't quite CC but thought that since alot of Cadets used Kohler it mignt be the same. the engine that i have has the wiring going into the shrowd above the starter and up toward the carb. i took off al the air cleaner hardware thinking it was up in there, but not. i guess i'm going to have to figure out the wiring diagram and do some snipping and terminal action and mount it externally. once again thanks Matt!
IH 560 tractor
'47 Ford 8N Tractor
'99 Chetech Pug 4X4
Old 07-15-2011, 11:04 PM
Vince_o Vince_o is offline
Whats it in? Dingo, Boxer, Termite? They put them things in lots of stuff.
Old 07-16-2011, 09:59 AM
Smile
Vince,it's in a '99 Chetech Pug UTV. i have all the manuals, but kohler is notorious for not having as assembled exploded view schematics. the flywheel side shrowd cannot be removed in vehicle. and pulling the engine is such an involved process, i think that nipping the wires where they enter the shrowd and adding terminals would be far easier.
IH 560 tractor
'47 Ford 8N Tractor
'99 Chetech Pug 4X4
