Old 06-26-2011, 08:20 AM
shortbox shortbox is offline
Default New guy from Saskatchewan
Hi I just bought a 1983 982 that has a 3pt hitch, PTO, steering brakes, and a 60 inch deck. The PO said that he ran it low on oil and it only ran on 1 cyl and was knocking when he parked it. I hope it repairable without a re-power. Once it is fixed I would like to get a tiller so my question is which tiller?
Old 06-26-2011, 09:46 AM
Sweet 982!
Old 06-26-2011, 09:59 AM
Ran low on oil and now knocks and runs on 1 cylinder? I bet it threw a rod. Onan parts are exorbitantly expensive; you can likely repower it for less than you can rebuild the Onan, and you'll have a better engine, too. There are many different engines that'll fit with minimal modifications. A Kohler M18 or M20 would be the easiest.
Old 06-26-2011, 10:36 AM
young enthusiest's Avatar
Hey a fellow Canadian!!! I'm in Alberta, pretty much on the Sask border along the number 7. The only tiller that will easily work for your 982 is a 3pth mounted one. I have only seen one and they are extremely hard to find and rediculously expensive. If your really good with fabrication, i beleive Matt G. Built an adapter that will make all the series 1 and 2 tillers work on a super. They are a little easier to find.
Where in Sask are you from? I have lots of tillers if you want one, and I also host a plowday that you just might be interested in coming to.
Take care!
Old 06-26-2011, 10:55 AM
I am in southeast sk about 20 miles from Melville. I need to get this engine fixed first and then get a tiller but I do some trucking when I am not farming that takes me into Alberta so I may have to stop in to see what you have. When is your plow day?
Old 06-26-2011, 11:07 AM
Melville? Wow that's a ways away. I'm thinking of having my PD In early august or late July. Before harvest anyway.
Matt, will a flat pan kohler, say a k341s fit in a 982? Flatpan kohlers are pretty plentiful up here, maybe one would fit?
Old 06-26-2011, 01:22 PM
I'm gonna go with probably not. Considering the amount of Kohler Magnum, Command, and Briggs Vanguard engines that are used in the newer Cub Cadets and other things, there's gotta be something around. Most any modern V-twin will fit in there as long as the PTO clutch can be positioned to line up and a driveshaft adapter made.
Old 06-26-2011, 04:59 PM
You have a great looking 982!
Old 06-27-2011, 12:01 AM
CC1650Dave's Avatar
I'm intrigued by what kind of structure you have it parked in (?)
Old 06-27-2011, 12:09 AM
Hola! Guten Tag! and That is a great looking 982 and it sounds like you got a great package with it!!
