Old 06-26-2011, 05:00 PM
krhoover krhoover is offline
Default Need your help... again
The sping that holds tension on the 1450 I have broke while mowing, so no big deal I thought, I'll finish up with that old 122 I got a few weeks ago. (theres just something about that thing I like) Opened the hood on it and was checking oil, ect, pushing on this and that and pulled on the s/g belt and the flywheel moves. I look a little closer and the thing is loose as heck, I think I can see it moving on the key. So I take off the front to get a better look and am not sure how to pull the clutch/ pto to get to the flywheel. I looked in the manusl on this site and can't find much about the teardown for this Heres the pics. Oh, and one more thing, I don't think it will, but will the mower deck off of the 122 fit the 1450.(see pics) The smaller deck gets in between things better. As always, its appriciated.
Old 06-26-2011, 06:17 PM
We have a member here that did a video on PTO removal at youtube.com
Here is the link.
http://youtu.be/7O4FE1tE_AM
I do not believe your deck from the NF will fit the WF
Old 06-26-2011, 07:32 PM
I have a deck from my 73 (NF) that will fit on my 129 and 149 (WF). So, it should be possible---note that these are all QA's though.
Old 06-26-2011, 08:21 PM
A pin-on, cast end deck will not easily fit the 1450. Not to say it isn't possible, but a lot of mixing and matching of parts would be necessary.
Old 06-27-2011, 09:49 PM
Talked with the guys in the toolroom at work today, they said the would cut a new keyway into the crank on this. The one guy says he thinks he can do it without taking it out of the engine. The question is, does it matter where the new keyway is cut? I mean can it be 90 or 180 degrees from the old one. Also, since I am going to be pulling the motor, any other parts that I should be replacing? I plan on tune up parts. Thanks
Old 06-27-2011, 11:52 PM
westofb's Avatar
westofb westofb is offline
I can't think of a reason why it could'nt be cut anywhere, most cut the new ones 180 degrees from the old one.
Jeff
Brookfield, MO
________________
Old 06-28-2011, 12:10 AM
It would make setting the timing a bit more fun.
Old 06-28-2011, 12:15 AM
westofb's Avatar
I was thinking he meant the key way on the pto shaft...maybe I read something wrong.
If you mean the key way for the flywheel, not sure about that, never paid much attention to the flywheel, it may be weighted to help balance the engine, it that is the case, I would think you would have to cut a key way in the crank and the flywheel, to keep them in the original position.
Jeff
Brookfield, MO
________________
cubs-n-bxrs's Avatar
Why would the PTO keyway have anything to do with the timing?
Old 06-28-2011, 12:23 AM
Originally Posted by Wild Bill View Post
Other end of the crank Duke....he's having issues with the PTO end.
I'm feeling a little special tonight! Sorry for the confusion! Back to the little party in my head now.
