Old 06-22-2011, 10:47 PM
RDBarnard's Avatar
RDBarnard RDBarnard is offline
Default wheel bearing trouble
Is anyone else having a problem with front wheel bearings not lasting?
Last Nov. I replaced the 34 yr old bearings on my 1650 and have gone thru three sets of them since. They last about three times mowing the yard. They are from cub cadet. Rich B.
Old 06-22-2011, 10:52 PM
william1041200's Avatar
there was a post on here within the last 3 months where someone had exactly the same problem with brand new bearings from cub cadet. I would recommend ordering some from Motion industries, or some similar place. You could probably get a better quality bearing for less than MTD prices.
104 to 127 conversion with dual 6x12s, hydraulics
snow/dirt plow
1200 Quietline 44" mower
QA-36 snow thrower
Old 06-23-2011, 06:44 AM
You might try these....
Old 06-23-2011, 07:03 AM
jo1429 jo1429 is offline
Have you checked the end play of your wheels. If the wheel is allowed to move back and forth too much, with too much end play, the steering knucle can contact the inside of the wheel rim causing undo strain and side loading on the bearing.
I believe the IH manual says .033 max endplay. See if yor wheel has too much and shim it up.
Recently had this issue and had to grind a little meat from the knuckle for clearance.Works fine now.
Joe
Old 06-23-2011, 07:20 AM
The bearings need to be sealed on the outside, and I typically re-pack new bearings with grease because they don't come with much from the beginning.
Old 06-23-2011, 09:39 AM
I use double sealed and don't ever grease mine.
Old 06-23-2011, 07:21 PM
hydrocub hydrocub is offline
I use NAPA , double sealed . High quality bearing . 7 -04292 .
Much better than the Cub bearing ...
Happy Wrenching
Old 06-23-2011, 08:00 PM
RDBarnard's Avatar
Thanks everyone!! Good info! Rich B.
Old 06-25-2011, 05:43 PM
IROCKWITHDIRT's Avatar
IROCKWITHDIRT IROCKWITHDIRT is offline
Had the same issue with my 129. Seems the Cub Cadet bearings are now made overseas. Running made in USA bearings now......... expect them to hold up better.
Wore out 129. Projects: 1969? 147, 1971 chevelle SS conv 402/4sp bench, 1965 chevelle wagon, 1973 trans am drag car, 1973 triumph 650 chopper, and oh yeah, working on the house too!
