I had no idea what I was getting into when I started to replace the wiring harness. I'm getting close though!
What the heck is the yellow square with a dark wire (actually blue) leading to the ignition switch?
147 w/ 42" deck w/ 3pt hitch all in memory of my grandpa's 124 |
I'm pretty sure thats a plug that would be used with an electric lift...check the wide frame diagram, its marked on there.
Jeff (teet)
CCC 1211 71 127 ![]() 102 122 1962 Original |
there is a place for it and the connector looks right... but i couldn't figure out why there would need to be a wire attaching the starter switch to the electric lift switch...
ya got me, but it might be for power only, and the switch might be seperate? I know that add on electric lifts come with a small wire loom, but I have no idea how it all goes together.
Jeff (teet)
![]() Quote:
auxiliary hot, for any thing that needed switched voltage, radio, cig lighter, or what ever.
