Old 05-28-2011, 10:44 AM
terkaa's Avatar
terkaa terkaa is offline
Default rolling/knocking noise from engine 1450
Hi,
Today pulling cart with 1450. I noticed rolling / knocking noise from engine. Noise was not very strong but I could hear it. Noise frequency went up and down with engine RPM. Could this be something serious like con rod or main bearings going ?
Tero
Old 06-01-2011, 03:00 PM
terkaa's Avatar
Hmmm... I believe I found reason for this. It is that starter bendix/gear does not like to come off from flywheel gear(stays on) Issue is mechanical. So I would like to know is it time for a completely new starter or is just rebuild kit with brushes bendix and bushings enough?
Tero
Old 06-01-2011, 04:41 PM
cub149's Avatar
cub149 cub149 is offline
Take the starter off and clean the shaft that the gear is on and then spray it down with silicon or oil. It should snap back once you do this. The return spring might be weak also so check it.
Chip T.
Drexel NC
Old 06-02-2011, 12:04 AM
william1041200's Avatar
When I got my 1200, the bendix was the worst problem, but it tended to stay disengaged no matter how much cleaning and oiling I did. Eventually, I won, and it gave in and worked properly. Try some EZ slide. I almost emptied my first can, and its not on my mower deck yet. I use it on everything that does not have grease fittings but should..... Next time I pull my motor, Im coating the driveshaft with it.
104 to 127 conversion with dual 6x12s, hydraulics
snow/dirt plow
1200 Quietline 44" mower
QA-36 snow thrower
Old 06-02-2011, 10:21 AM
powerpooch's Avatar
powerpooch powerpooch is offline
I cleaned the starter on my 1250 during the winter. I was using it for snow blowing but the starter would jam when trying to start the engine. The starter was really easy to clean. I used http://cubfaq.com/kstarter.html to help me, but I didn't need to bend the wrench, a regular socket worked and I used an impact gun to get the nut holding the bendix gear off.
After I did this it never had a problem even on the coldest days of the winter.
Old 06-03-2011, 04:00 PM
terkaa's Avatar
Hi,
Did some oiling and cleaning today. And I noticed that there is something wrong with bendix it slips both directions. But it seems that this 13 tooth bendix is hard to find. I have checked Ebay and CCspecialties but neither seems to have these. If I understand correctly Kohler no is KH-47-749-02 anyone know where to find one?
Tero
Old 06-03-2011, 04:11 PM
The part number has changed to: Kohler # KH-45-755-16-S
Just do a google search and you should see several places with them for sale. Prices seem to vary all over the place.
Old 06-03-2011, 05:26 PM
cub149's Avatar
Originally Posted by terkaa View Post
Hi,
Tero
What do you mean it slips both ways? It should move both forward and back on the shaft, there is a spring that returns it back away from the flywheel. Is this what is happening or am I misunderstanding you?
Chip T.
Drexel NC
Old 06-03-2011, 11:56 PM
terkaa's Avatar
Bendix gear rotates freely to both CW and CCW directions. Bendix is a two part unit (inner part with threads that slide on starter shaft and outer part with gear) If I lock inner part with threads and rotate gear with hand it rotates in both directions(when bendix is off from starter) Is this how it should work? OR should there be a one-way clutch inside bendix gear?
Tero
