Hello CC Fans. I am back with a few questions. I gave up locating a nice original CC Diesel. Instead I bought a "green" Diesel that I use for my yard mowing. I recently saw a nice original low hour 2072 for sale. It has a 50 mower deck. What are your thoughts on this tractor? Any known issues with this model? It will be a "show/collector" tractor. I may use it for general duties but not mowing. I don't have details but it is a one owner. I believe this is an MTD built machine.
Thanks in advance for your input.
Ken Old fart - new to Cub Cadets Looking for a nice original low hour 1772 or 1782 |
2072's are great machines. The rare early ones had the Onan B48G motors and then they switched over to the Kohler Magnum 20 engines. They were CCC built from 1987 to 1989 and have the aluminum rears in them. They came standard with turning brakes, front remotes and power steering. Options were rear pto and a cat 0 lift.
As with all machines built with the aluminum rear you need to check and see if all the mounting bolts are snug at 30ft/lbs that bolt the rear assembly to the frame and check to make sure the front tabs on the assembly are not broke. There are fixes for all these issues so it's not that big of a deal but would make a good bargaining tool if there are issues. Got any pics of it?
https://www.onlycubcadets.net/forum/...ead.php?t=1024
1572, 1864 x2, 1810 x2, 1863 & GT1554(Dad's Ole Mowers), 1811,782D, 1872 x2, 782DT(Sold), 3235, 1860, 1772 with 3-point and Turbo. |
I talked to the owner this afternoon. It is in the shop getting the starter replaced. Is the starter an issue? The tractor has 7xx hours. The owner also stated it has a rear PTO but no 3pt. Based on my research one cannot have a rear PTO without a 3pt. Is this correct? The owner bought the tractor new in October 1989.
I found the CL listing. It does not have rear PTO. Paint looks clean but almost looks like it was repainted. Tunnel cover has been modified with gauges and the dash tower has had some added things to it as well. I believe this machine is overpriced in my opinion. $3k would be a diesel or this machine with rear PTO and cat 0. The Kohler Magnums are pretty common having starter issues not engaging the flywheel.
Thanks for posting the pictures. The owner states it is original paint and he adamantly states it has a rear PTO (the pics do not show a PTO). The front tires were replaced. The tractor is currently in the shop getting the starter replaced. He will call me when the tractor is returned. The extra gauges are oil pressure and oil temperature. Nice to have but not necessary IMHO. It still has the oil pressure indicator lamp on the dash. I don't know if it is still functional. He has the original bill of sale along with the OMs.
I agree, over priced. What would be a "reasonable" price for this tractor? My interests in this tractor are #1-close (45min) and #2-nice original one owner. But my preference is a nice original 1772/1782 but nothing within the last couple years.
In my mind, max would be about $1500, but that is a nice looking tractor, and I can't recall finding one that nice near me in a long time.
I add oil pressure gauges to my machines, but I swap them with the hourmeter and mount the hourmeter under the fuel tank.
RUN IN THE RED 782 w/50c deck (red); 782 dual stick, 44c deck (y/w); 1050 w/38c deck; 1864 w/54" GT deck; 1872 project Cub Cadet Pro Z 560 L 42" power angle snowblade, #2 tiller, 2-QA42a snowthrowers, 450 thrower, #2 cart; 54" Haban blade; Brinly box blade, 48" dethatcher, moldboard plow; Agri-Fab sweeper 1200, 1863, 1864 parts machines |
I received pics of the mower deck. Looks too nice for 7xx hours of operation. Also, the seller is having the engine disassembled for inspection. He said nothing is wrong with the engine, he wanted to know everything was okay.
This is starting to "smell" and I am going to pass on this machine. Either keep looking for a nice 1772/1782 or another "green" machine. Thanks everyone for your replies.
| Thread Tools | |
| Display Modes | |
