Old 10-02-2022, 07:22 PM
beancent beancent is offline
Default 782 vibration after hearing pop noise.
While plowing snow last winter, I heard a bang noise and then started to feel an unusual vibration through the frame and steering wheel of my 782 which is a red IH model. The tractor starts up and moves around like normal but still has the vibration. My first thought was to check the drive shaft and cloth connecting disks, But they looked normal. My next area I thought would check was the flywheel to see if any magnets came loose, so I pulled the motor and now have it hanging from my engine hoist. Does anyone have any Ideas on what I should be looking at.
Old 10-02-2022, 08:30 PM
Tom Dowling Tom Dowling is offline
If your flywheel came apart I don't think it would be able to keep running.
Is it a KT17? Was it still running on both cylinders?
Old 10-03-2022, 05:23 AM
Yes it is a KT 17 series ll. Yes it is running on both cylinders. The magnets are glued to the back side of the flywheel and can break loose but would they jam in there and wedge between the block ? My next step was to pull the flywheel and with winter comming possibly a tear down on the motor. I have never had this motor out. Can you still find parts for this motor
Old 10-03-2022, 06:37 AM
Having a 782 myself, I would re-examine the Flex Disc's, and the Drive Shaft Couplers, to see if something is out of round.
Old 10-03-2022, 07:01 AM
mrfred54 mrfred54 is offline
Remove drive shaft and start engine to see if it still vibrates
Old 10-03-2022, 04:49 PM
Good Idea I'll try that and let you know what I find.
Old 10-03-2022, 05:16 PM
1711Cub's Avatar
1711Cub 1711Cub is offline
Lightbulb
The KT17 regardless of series one or two will break connecting rods. Sometimes they will not damage the block or jugs. Pull the heads and see if both pistons move when turning the crank.
Old 10-03-2022, 05:39 PM
You can accomplish the same thing with removing the Spark Plugs and insert a dowel rod into the chamber, to see if it goes Up/Down.
Old 10-03-2022, 06:34 PM
you may be able to see them move just shining a light in the plug hole
Old 10-03-2022, 07:46 PM
Will check to see if pistons are moving and report what I find.
