Hello
New member here. I'm working on my 1641 in this range of serial # below. {1641 (145-653-100) - Cub Cadet Garden Tractor (SN: 821060 - 880000) } When I started It this evening it was really smoking. Where is the best place to buy parts/ Rebuild kit ? Thanks in advance for your help. Model #303447 Type 0447-01 Code 940916 16hp.jpg . |
I would suggest you take an aspirin and maybe a short nap.
I have owned several 16 hp Vanguards that smoked and none of them required a rebuild. Might be best for you to figure out what is causing the smoke and report back before all the jingle runs out of your pockets? |
Thanks.
I will take that advice. When I purchased it a few weeks ago it was fine. It is (freshly rebuilt) was the story. It sounds great. I will pull the plugs and take a look. Also Run a compression check. I will take the muffler off. and check things out . I will post a picture of the muffler. It does not look like it is burning good on both cylinders. Thanks |
I run compression test.
150psi even both sides. ![]() Right Plug looks normal, Left Plug Wet. Gas/Oil. So spark check. Right side ![]() Left side ![]() I will look when it gets dark. I think it has not had spark on this side for a while. Here is a picture of the Muffler. vg.JPG . |
Update.
No spark on left side. . |
Update.
The coils check the same Ohm resistance . The flywheel is rusty. I will clean this. I am going to check the gap. Does anyone have that info? flywheel.JPG . |
The kill wire that attaches to the coils has diodes in it. I've read that if they go bad it can cause spark failure. I had to replace the one on my 1641 because it got pinched in the shroud.
Cannon |
![]() Quote:
I will check that. . |
The armature air gap is .008-.012.
If you can spin the engine, just remove the kill wire from both armatures and see of both of them spark. I just replaced a kill wire because of an open diode and one side wouldn't fire. Some multimeters can check diode function. |
I want to Thank both of You.
Mike McKown for slowing me down . ![]() ![]() And Cannon51 for telling me about the wire. ![]() And Mike for instruction of leaving the wire off ![]() It was that wire. I swapped the coil side to side Tested everything. Blah Blah ![]() Then left the wire off and (Bam) Here's a picture wire_LI.jpg So 2 more Questions. #1: Where is the best place to buy this wire? Also there was nothing hooked to it on the outside of the engine. #2: Does it have to be hooked in the wiring? . |
Thread Tools | |
Display Modes | |
