Old 07-31-2021, 12:26 PM
Deegle Deegle is offline
Default Need help with gas leak from carburetor
Hello all. I’m new here and a novice at working on engines. I had a gas leak coming from the carb of my Cub Cadet 125. I ordered a new carb and installed it. Now the leak is worse. Any advice would be appreciated. Thanks!
Old 07-31-2021, 06:28 PM
The leak is more then likely not from the carb then. Start at the tank
and look for leaks in the hose and fittings. You also have a glass
sediment bowl between tank and carb that has a shutoff below it.
Also has a gasket. Good chance one or both of those is leaking.
Simple to replace. Sounds like a good time to replace fuel lines,
fittings and clean it all up including tank. If that stops your leak I would
put the Kohler Carb back on it. Unless you replaced it with Kohler, most
folks don't. Good luck, let us know what you find.
Ken
Old 07-31-2021, 08:13 PM
guyina4x4's Avatar
guyina4x4 guyina4x4 is offline
Where'd you get the carb?
I got one from isavetractors.com that came with a bad float.
His carb worked worse than the original.
JD x475
Old 07-31-2021, 09:20 PM
My bad on referring to the carb as a Kohler carb. I believe if its the
original one it would be a Carter.
Ken
Old 08-04-2021, 10:33 AM
Default Thanks!
Thanks for the help guys. I took it back apart and reassembled it and it no longer leaks. I'm guessing something just wasn't seated property. Thanks again!!!
Old 08-11-2021, 07:32 PM
jbrewer's Avatar
jbrewer jbrewer is offline
Good work Deegle! You just fixed your first cub problem :-)
Welcome.
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
It's only original ONCE!
