I have a 1450 that I use as my work tractor and a 1250 in decent shape I need a motor for. I was checking around and found a 127 and a 105 both need minor work and both are about the same price. I'm leaning towards the 127 because worst case I have a block to rebuild for my 1250. What are everybody's thoughts on the best option? I will be using it as my primary mower.
The K301 block in the 127 probably isn’t drilled and tapped for the electric PTO clutch.
Doug Dad's 122 w/42" cast deck, spring assist, lights,weights, rear lift 1250 w/hydraulic lift, lights,weights, spring assist. 50C deck converted to an A with front wheels 44C deck converted to an A with front wheels. QA-36A 42" blade |
![]() Quote:
i.e. flywheel, stator, regulator, starter motor |
Thanks for that info. I didn't realize the blocks would be that different. It appears that all of the stuff to bolt on to the engine was stripped off and put in boxes. When I got the 1450 the guy threw in the 1250 and 4 boxes of parts and a spare hydro. It appears to have all of the electric pto parts .
I don't think I would want to sacrifice an intact 127 to fix up a 1250. The 127 is pretty nifty little machine. Correct me if I read you wrong.
![]() Quote:
Agree with you for sure.
61 and 63 Originals 123 (2) 782D 106, 147, 122 102 parts It's only original ONCE!
![]() Quote:
and use it as is. |
Thread Tools | |
Display Modes | |
