Old 11-05-2017, 02:13 PM
Bob brown Bob brown is offline
Default Steering axle mount to frame
Where the pivot bolt goes thru the frame, the holes are worn oversize. Any ideas as what to do with them. The pivot pin was rusted in the axle, and all the wear was on the bolt and frame.
Old 11-05-2017, 02:17 PM
*Get your welder out and repair it with a new bushing. Cut the old one off the bolster and weld a new one on.
*Reem it and put in a bushing.
*Reem the entire assembly and make an over sized pin.
*Cut the bolster off your tractor. Cut a good bolter off a parts tractor, weld good bolster to your frame.
None of these are too difficult to figure out......
Old 11-05-2017, 03:08 PM
DeltaCub's Avatar
DeltaCub DeltaCub is offline
I have used these in the past. The price has gone up some. Cut the old bushings off and weld in the new ones.
https://www.ebay.com/itm/Cub-Cadet-F...gAAMXQ855RpkVF
Queen Of The Quietlines!
Old 11-05-2017, 03:13 PM
Stephen.Mellish's Avatar
Stephen.Mellish Stephen.Mellish is offline
Bob,
For the first option that J-Mech has listed, you can contact forum member Jeff in PA and he can supply you with new bushings and pivot pin. He does very good work on the parts he makes. It appears that at least one sponsor at the top of the page has the OEM bushings and pivot pin too. And as DeltaCub pointed out, eBay has them.
The Collection, so far: Cub Cadet 100(x2), 125(x2), 123(x2), 70, 71. Adding more when I can find them.
Old 11-05-2017, 04:25 PM
Check out this post from when I did my 126.
http://www.onlycubcadets.net/forum/s...ngs#post278799
Old 11-05-2017, 09:51 PM
mortten mortten is offline
The link Delta Cub posted is Patton Acres eBay site.
Doug
QA-36A
42" blade
