OK, replaced the starter and solenoid on my 1882. Apparently I've done something wrong with the wiring - IT SPINS BACKWARDS!
I'm going to attempt to attach a pic of the mess I've made. If there is anything obvious please tell me. As a note - I believe (or I think I remember) the starter spun correctly before replacing the solenoid (it must have as there are marks on the teeth (cogs) of the starter) NOTES: The red cable standing straight up comes from the battery positive post The red cable with the heat shrink is going to the starter (only one possible connection there) The green wire connects to a red wire and is terminated between the solenoid base and the frame of the tractor with a ring terminal (doesn't show the termination in the pic) The fuse holder (red and black wires together) are on the battery side of the solenoid. The red wire with the female quick slide is connected to the solenoid male tab. I'm guessing I've got this configuration discombobulated. |
Is the battery hooked up correctly?
![]() Queen Of The Quietlines! ![]() |
The positive and negative is correct. I suspect I've got something wrong at the solenoid.
You sure? I don't think even if you had the battery hooked up backwards it would spin in reverse. The starter for sure won't engage even if it is spinning in reverse. The bendix is a screw style. If it spun backwards, it would pull the starter gear to the starter, not out to engage the flywheel. Even if you wired the solenoid wrong, it wouldn't spin in reverse. You better check again.
![]() Quote:
If the starter spins in reverse, you have two situations (A) Battery Cables hooked up wrong (B) You have the wrong starter.
![]() Quote:
There has to be more to the story. Why was the solenoid replaced?
1572, 1864 x2, 1810 x2, 1863 & GT1554(Dad's Ole Mowers), 1811,782D, 1872 x2, 782DT(Sold), 3235, 1860, 1772 with 3-point and Turbo. |
![]() Quote:
Then it is spinning the correct direction. Do as DeltaCub suggested above.
After replacing the starter I was getting only a "clicking" sound from the solenoid. So I replaced it as well.
Thread Tools | |
Display Modes | |
