Old 03-15-2016, 12:39 PM
riesedesperado6170's Avatar
riesedesperado6170 riesedesperado6170 is offline
Default 1872 hydro
Well then I went drove this thing around after figuring out the wiring issues. I found the tractor goes faster in reverse then forward but I try to adjust linkage and nothing changes. I also see that the valve on right side as you sit in Seat has a slight leak. could that cause my problem.
Old 03-15-2016, 01:19 PM
FrankF3's Avatar
FrankF3 FrankF3 is offline
What would happen if you were to swap the valves left to right and right to left?
1989 - Cub Cadet 1772
38" Lawn Sweeper #196483
60" Haban Mowing Deck #196374
Old 03-15-2016, 01:30 PM
Has the pump been apart?
Old 03-15-2016, 03:10 PM
haven't swapped them yet. sam I don't now if it ever been a part I got it second hand from one of the guys on here and he took it to a shop to be checked and they said it was good pump. but I don't know if they took it a part. I know that they put one seal in it and it the out side one on input shaft for discharge pump SU-9008000-6201 part number and number 27 on look up sematic.
Old 03-15-2016, 03:38 PM
cubs-n-bxrs's Avatar
Thinking the same thing Sam. Sounds to me like the swash plate got put in 180*out.
Old 03-15-2016, 04:41 PM
If they changed the trunnion seals as Kelly said they may have put the swash plate in up side down. The swash plate has a lug on the back side to limit how far it moves in reverse. Upside down would limit forward.
Old 03-15-2016, 09:27 PM
I never had one a part. how much fun is to take it apart. so is any way to tell for sure with out taking it a part
Old 03-16-2016, 12:10 AM
Will the lever travel all the way in the dash slot? Or does it just stop?
Old 03-16-2016, 09:24 AM
Only goes 3/4 up the slot maybe in forward and reverse goes alway end of slot
Old 03-16-2016, 10:31 AM
Pretty sure someone was inside that pump and put the swash plate in upside down. Read up on how to rebuild the pump. The info is in the service manuals for most of the hydro tractors. It's not all the difficult to do just take your time and make sure every thing is absolutely clean.
