I have a Narrow Frame Hydraulic lift that is missing the Hydraulic lift actuating handle (#15 on the parts diagram) and link (#12). I can find the lift rod but not the link for sale.
Would anyone be able to measure their existing link so I could try and reproduce one? A very good picture of one mounted would also work as I could lift my dimensions off of the picture. Also a picture of the press on nuts used would be good so I can pickup the same style. Link Dimension: Diameter Distance from center to center of each leg Leg lengths Thanks in advance, Bruce |
Of the two that I have here one has a VERY homemade link, the other looks like it belongs there.
I didn't get a diameter for you, but it's about as close to the size of the hole in the handle and lever as you can get. From the center of one bent end to the center of the other is about 2-5/8" and each bent end is right at 1/2" measuring "inside the angle". If you can't tell from the picture, someone used one of those self tapping stamped sheet metal nuts on one end and on the other end is a push nut that is shaped like a hat that Charlie Chan used to wear (sorry, but that's what it is shaped like). I hope this is of some help.
There is a NOS one on Ebay right now, pretty pricey at 100.00. Just a heads up.lol
Mark ![]() 1971 Model 73 - Hydraulic lift,Fenders,Creeper,Lights,Sleeve hitch and Weights 1967 Model 102- mower 1965 model 70 - weights,rear lift and spring assist Model 100 resto mod project, rear PTO, hydraulic lift QA42 snow thrower 42in front blade Grandpa's F-12 and Super M |
I saw that too, wow
yes I saw it too hehehe
Thanks for the pic and info, just what I needed!
Thread Tools | |
Display Modes | |
