Old 11-03-2014, 02:16 PM
SharkyOhio's Avatar
SharkyOhio SharkyOhio is offline
Default K321 Trouble
I have a model 149 with the K321A engine.
The engine was running fine, then suddenly started giving me problems. It is runs pretty smooth at low idle, but when I give it throttle it bogs down. It keeps running, but will not reach max RPM.
My air filter was pretty dirty, so I replaced it. No luck. I reset the carb, following the instructions in the manual. No luck.
My points are fairly new; installed about a year and a half ago. I took off the cover, and they still look like new.
Any ideas what the problem might be?
Tractor #1--1972 Model 149 with rear lift
Tractor #2--1972 Model 149 with rear lift
1A tiller w/both extensions, 38" & 42" Mower Decks, Wheel Weights, Ohio Steel Fabricators 10" mold board plow, two 42" snow blades, QA-42A Snow Thrower, Brinly Sleeve Hitch
