Old 09-28-2014, 10:22 PM
rdehli rdehli is offline
Default 1864 running warm question
my 1864 seems to get warmer than it should under normal operating conditions. or so I am thinking. After running for 20-30 minutes you cannot touch the dip stick, also will spit and sputter when under load sometime when it appears hot. Any remadies out there ? thank you in advance
Old 09-28-2014, 10:25 PM
jimbob200521's Avatar
What oil are you using? When was the last time you pulled the tins and cleaned the cooling fins up from grass debris, junk, and gunk? How many hours are on this motor? What are you doing when it "overheats"? Gotta give us some more info
-Ryan
Old 09-28-2014, 10:35 PM
the tractor has 475 hours ... bought from a cub dealer in July I am assuming it has kohler # 30 in it . it feels like decent air flow when you stand at the front of the tractor, but I need to pull the shrouds off and do some investigasting.
Old 09-28-2014, 10:37 PM
I will run Case IH low ash 30 in the summer and 10 w30 or lighter in winter
Old 09-28-2014, 10:54 PM
after mowing every time it gets blown off completely, engine compartment, deck , and everywhere I can put the 3 ft air extender. The thing that puzzles me is , that this is by far the cleanest tractor I have ever bought.
Old 09-28-2014, 10:55 PM
could it be a timing issue? if so how is that corrected. But is starts right up and seems to run strong.
Old 09-29-2014, 12:27 AM
It running lean. Pull the carb and clean it. Probably junk in the bowl. Might as well go ahead and clean the fuel system out. Drain the tank.... . You know the drill. If you find small bits of rubber, replace the lines and fuel pump. I promise, it's junk in the carb. Glad to see you keep your machine clean. Oh, on the timing thing, no it's not adjustable on a Mag. Can't be changed.
Old 09-29-2014, 08:36 AM
Jon
That's a CH not a Mag
Old 09-29-2014, 09:15 AM
Jon
Yeah..... But, they're the same. My bad.
Old 09-29-2014, 09:16 AM
Just looked thru the technical library, is there a download available for a service manual for the 1864, should have one of those.
