Old 08-26-2014, 10:10 AM
RicochetFord RicochetFord is offline
Default Wide Frame Mech PTO
Can some one tell me a way to determine if the Mech PTO springs are bad?
The reason I ask is because I keep having problems with the three fingers becoming loose and falling out of the center button. I have used the gauge on reassembly but as soon as it spins a few time with the starter the fingers are rattling. The springs are bent or bowed when I take it apart. I think they are broken from over tightening because they were bowed when I took it apart the first time. If I reassemble with the bow out the next time I take it apart the bow is the opposite way. It's like they have lost their spring. I would just like confirm this before a spend the money on new ones.
The PO had ran it without a working PTO long enough the button and fingers were worn off in the middle from the rock shaft. The disk itself looks brand new. I took it apart and replaced the worn pieces but can not get the fingers to stay tight or the clutch to work more then a couple of times before it has to come apart again. This always ends up getting the button on the rock shaft too.
Old 08-26-2014, 11:58 AM
Maybe a picture would help.......
Old 08-26-2014, 12:06 PM
It has been my experience that if the flat 3 finger springs get hot, they loose their ability to "spring" once this happens turning them over is no different than putting a regular old piece of tin in there.
If everything else is good, new springs are available.
Old 08-26-2014, 12:10 PM
jkier's Avatar
jkier jkier is offline
https://www.youtube.com/watch?v=Q4Jk8tBGB8M
Check out around 6:56
Looks like just the ends of the fingers should be bent slightly not the plate itself
106 Needs a clutch-------107 (Lent to my brother)
123 w/hydro lift & qa36--126 w/creeper and lift
127 restored--------------129 50" mowin machine
129 w/hydro lift-----------147 plow horse w/tiller
149 auction score---------782 KT17SII
Old 08-26-2014, 01:07 PM
Looks like he forgot the three other nuts....
Up to 530 and counting...
Old 08-26-2014, 01:23 PM
Thanks guys, that confirms my suspicions. Hurry up payday!
