Old 07-26-2014, 05:47 PM
TIMCRUTCHER TIMCRUTCHER is offline
Default Wiring harness advice
Redoing my 71 (another thread) and have a new harness. I ordered it for a 71 and the label says for a 70-100.
Problem is that it is for a push button starter and mine is key start. It has two wires to the key switch and mine requires three.
Is this a simple fix or should I send it back?
Thanks
I don't use my Cub. I just work on it and look at it. So far it's holding up very well.
Old 07-26-2014, 07:21 PM
the 2 wires that should hook to the push button will instead be hooked to the solenoid and you have to make a wire to go from the start prong on your key switch to the solenoid. with that said im not sure how easy it will be to do, i guess it all depends on if the wires are long enough.
Old 07-26-2014, 07:54 PM
If I wanted one spliced and questionable, I would just use the old one.
Old 07-27-2014, 10:32 AM
Tim, contact Mike Lamar on this site(MLamar). He does awesome work and has great prices.
Old 07-27-2014, 01:46 PM
Merk Merk is offline
I'd return it.
I'm sure you can make it work, but WHY? Just get the right one.
That is what I would do.
Project Uncle Dick
Cub Cadet 70
Old 07-27-2014, 02:05 PM
make your own, i hand make all mine and it only cost about 40 bucks and takes about 2 hours to make. nice thing about making your own is that you can route it however you want, i try to make mine with as little wire showing as possible so it looks clean.
