Old 11-19-2015, 01:29 PM
ab147's Avatar
ab147 ab147 is offline
Default PTO woes
I have a 149 that stopped running earlier this year, and I swapped the engine from a 147 into it, and have been using it to just tow things around when needed, well, winter is coming and I have used the 149 for the snowblower, so I hooked it up today, and seems that the pto is running all the time, and the snowblower with it. I looked in the archives to try to find out how to adjust it, went back to the barn and things don't look like they do in the drawings in the archives. The first two pics I'm including are what is in the 149 as it sits now. the third pic is the pto that was on the engine that I took out of the 149. Any help? thanks
147 w/mower deck, plow and rototiller owned for 22 years
149 new to me in 2010
2 more 149's with a a42a snowblower new to me in 2011
Old 11-19-2015, 01:47 PM
jkier's Avatar
jkier jkier is offline
The 147 Motor has the older style pto setup to be used without the brake
The 149 frame has the brake lever, you'll need an old style lever to actuate the PTO
Edit: You could also just swap the PTO's from the old 149 motor to the 147 Motor
106 Needs a clutch-------107 (Lent to my brother)
123 w/hydro lift & qa36--126 w/creeper and lift
127 restored--------------129 50" mowin machine
129 w/hydro lift-----------147 plow horse w/tiller
149 auction score---------782 KT17SII
Old 11-19-2015, 02:04 PM
Sound like the best solution.
Old 11-19-2015, 02:11 PM
ab147's Avatar
I have a parts 149 tractor that has the same lever and button as the 147, this has me confused. thanks for the replys.
Old 11-19-2015, 05:35 PM
Merk Merk is offline
The early 149s had old style PTO. The newer style PTO has a brake built into it.
I do not know when Cub Cadet change to the newer style PTO.
Project Uncle Dick
Cub Cadet 70
Old 11-19-2015, 09:50 PM
I think it was '74 when the newer style with brake started appearing, not for sure of the month, though.
Old 11-20-2015, 08:46 AM
ab147's Avatar
yesterday I swapped out the lever from another 149 that I have as my parts tractor's already was missing. The one in the pics came out real easy, not so easy on the other, but it's in and needs to be finished.
Old 11-20-2015, 06:50 PM
ab147's Avatar
finished up today and everything is back together. Didn't take any time putting the hood or nose piece back on and the hood is crooked but it's on and it will work. Pic is of the new lever.
Old 11-21-2015, 09:08 AM
jkier's Avatar
Looks like you have it sorted out
Old 11-21-2015, 12:08 PM
Do you have a button in the lever on the rockshaft?
