Hey fellas I just changed the filter and fluid in my new 125 and now I can move about a foot in reverse and nothing going foward. I changed everything because the gasket was slightly leaking and it'd never been change yet since I owned it. Any ideas what the problem is I'm very new to this.
What filter and fluid did you use..???
And how much fluid did you put in?
It's the correct trans filter and I put just shy of two gallons of hytran. I filled till it poured out the fill hole. Ran it for a while tried to move it foward and reverse then topped it off.
Is the lever for the pressure relief valves on?
Is the "input shaft" to the hydro unit rotating..???
The input shaft is spinning and the lever is in the drive position.
Did you clean out the rearend good When you drained it? It sounds like a plugged filter or the wrong filter.
I cleaned all the gunk out then sprayed with brake cleaner and wiped it all down. The filter is from ihccw and says it's for a cub 125 hydro. I'm 90% sure it's the correct filter unless I was sent the wrong one it says it right on it though.
It seems like you did everything right.
Thread Tools | |
Display Modes | |
