I have a set of wheel weights that i had given to me i was told that they were foo a old wheel horse, I tried to fit them on the wheel and they fit on the outside of wheel and i can get the bolt holes to line up so my question is what kind of bolts should i use to mount them to the wheels.
Carriage bolts, they have the square shoulder on them. They will slide in thru the back of the wheel.
any idea on how long i should go
That would depend on the weight..put one in a wheel and measure between the wheel center where the bolt goes and the outside of the weight, and add some for the nut, washer, and lockwasher.
get long ones and cut them off with a hacksaw or something..
Sold everything but one. 1211-snow pusher, cab ,54 inch plow, loaded tires (all 4) Gilson wheel weights, X-trac fronts- soon to have power steering and dual hydraulics |
I just use all thread and put a nut on each side of the rim and it will stay. Then slide your weights on an put a nut on to hold them on. Alot cheaper than long carriage bolts. Works on my tractors. Just don't stack to many on there.
Home depot sells 10' lengths of 1/2" threaded rod in the electrical section, with the EMT/conduit and nuts n washers.
Clay |
Thread Tools | |
Display Modes | |
