Old 07-25-2010, 05:52 PM
pepilapeau pepilapeau is offline
Default trunion repair
Ok, I'm getting ready to do the trunion repair on my 782 and I am not real sure how to get the speed control bracket off so I can get to welding up the trunion? I can see down where it conects bot unsure of how it comes off?
Old 07-25-2010, 08:52 PM
gcbailey's Avatar
gcbailey gcbailey is offline
I just threw some wet rags over my hydro when I welded mine...
Gary
Old 07-25-2010, 09:42 PM
I plan on doing the wet rag thing but I want to remove this bracket so I can repair it also. It is very worn and needs to be re-shaped also. I can't belive how dirty this beast is! I started to scrape all the years of dirt from it. The arrow points to the rod but I do not see a way to remove it? The pics i have found for the repair show this bracket removed from the pump?
Old 07-25-2010, 09:54 PM
jbollis's Avatar
jbollis jbollis is offline
There should just be a snap ring on the outside end of the rod.
Sold everything but one.
Old 07-25-2010, 10:12 PM
WOW...that's worn really bad...you can see where the little button on the trunion spring is about to come through the side of the rectangular hole.
Old 07-25-2010, 11:06 PM
jbollis, is correct. There is a snap ring right where your arrow is.
If it were mine I would pull the transaxle out, wash it and then repair the trunion. A clean transaxle runs a lot cooler than a dirty one. Plus, it's a lot easier to repair the trunion with the transaxle out of the tractor. Just my opinion...
Old 07-26-2010, 06:40 AM
yeah I would love to just yard it all out but I do not have the time. I got limited space in my garage and don't need another project strewn out all over the place. I am planning on cleaning up the pump as good as I can while the fenders are off. The trunion is worn right through as you can see But I'm sure I can weld her up pretty good. I just want to put the old girl back to use as soon as possibe.
Old 07-26-2010, 02:21 PM
zelda's Avatar
zelda zelda is offline
I did my 149 not long ago. . . For me it was easier to take 15 more minutes to pull the hydro than to fight the confined space in between those frame rails. plus cleaned it up. Took the whole Hydro chucked it in the vise. Turned out great. Had enough room to fine tune it with a file.
Old 07-26-2010, 05:08 PM
I think I am going to order this trunion repair kit for my 1250.
http://www.xtrememotorworks.com/Part.../CC-28-001.htm
Old 07-26-2010, 07:38 PM
If you've already got a welder, how is that easier than welding and filing the corners? Something about welding that huge thing on there and throwing all that heat into the seal doesn't really sit well with me...
