Can't get the mule drive off to work on the front axel.Checked owners man. found nothing,looks like remove 2 pins to drop from lift and slide forward.Am I missing something? Its been on there a long time.need help
If the belt is off, you should just have to pull down on the spring loaded QA rod running horizontal to the front of the frame (looking at the tractor from the front), and just pull the mule drive assembly forward til it drops....the rod is kinda tucked up under the front of the frame.... I can take a pic of mine if you still need help.
Jeff (teet)
CCC 1211 71 127 ![]() 102 122 1962 Original |
Thanks, That did it I didnt want to have to break out the heavy artillery(really big hammer) I saw that there but didnt see how it worked.
No problem, glad you didnt have to break out the big guns
![]() Jeff (teet)
