Old 02-27-2011, 03:39 PM
Sminkey
Guest
Posts: n/a
Default 124 rear Axle play...
Hey guys, both of the rear axle shafts move in & out a good bit. I noticed when I push them inward the axle shaft hits the differential pinion shaft?? I don't think they should be in contact with each other. The rear axle seals were leaking and will need replaced, what else should I replace while I'm in there?? I haven't noticed if the retainer rings on still on the axle shaft, but they wouldn't keep the shaft from sliding inward, would they?? Thanks
Old 02-27-2011, 03:56 PM
Sounds normal. I wouldn't worry unless the clips are gone. I would put in axle seals while you are in there.
Old 02-27-2011, 04:25 PM
Sminkey
Guest
Posts: n/a
Ok, thanks Matt!
Old 02-27-2011, 05:31 PM
young enthusiest's Avatar
Matt, what wears and causes that endplay? I'd like to know because my 782 and 1650 do it pretty badly too. Thanks!
Old 02-27-2011, 06:00 PM
They are likely that way from the factory. The snap ring prevents the axle from being pulled out, and the pin for the spider gears keeps the axle from being pushed in. I suppose the end of the axle and pin may wear a bit, but probably not even enough to be noticeable.
Old 02-27-2011, 08:53 PM
Do I could take up excessive play with a washer or 2?
Old 02-27-2011, 10:00 PM
You probably could, but shimming them up will cause the axles to be a little tighter than they are now thus causing more wear on the parts that are already worn a little. Then you'll get more sparkles in your oil causing more wear everywhere else in the transaxle. Go buy a new car or truck raise the rear tires off the ground and there will be some end play there too, I don't think it's worth messing with and could be more harm than good.
Old 02-28-2011, 08:55 AM
Okeydokey thanks for the help! Sorry for hijacking your thread!!
Old 02-28-2011, 08:53 PM
loghouse loghouse is offline
Default Rear axle tutorial
Hi guys,
Has anyone done a rear axle tutorial on here somewhere? It sounds like a lot of people could benefit from one. Matt? We always enjoy the helpful things you post on here. Yosemite Sam? Your knowledge runs deep, any step by step procedure? Thanks for all the help you all give us.
Greg
Old 02-28-2011, 09:30 PM
What do you mean by 'rear axle tutorial'? That could potentially cover a lot of things. I replaced the transaxle on my 1872, and had it completely apart, and this is documented on my website. That covers a few things, most of which you wouldn't typically need to do.
